Dental implants
Dental implants are a durable and natural option for replacing missing teeth.
Enhance yoursmile.beauty.
We offer treatments designed to give you the radiant, harmonious smile you've always wanted.
At International Dental Centre, we understand that a beautiful smile not only enhances appearance but also boosts confidence and improves quality of life. As specialists in cosmetic dentistry in Fuengirola, we offer Smile Design, a customised solution that combines art and science to transform and perfect your smile according to your facial features and aesthetic goals.
What is Smile Design?
Smile Design is a comprehensive and personalised process that focuses on improving dental aesthetics, adapting the smile to the patient’s features to achieve a perfect balance between functionality and beauty. We use advanced technologies to plan and preview the final result, ensuring that the new smile fits not only the shape and color of the teeth, but also the facial structure and expectations of the patient.
The process begins with a detailed consultation, where our specialists will evaluate your oral health, take photographs, impressions and x-rays to understand the structure of your teeth and gums. They will also discuss what aspects of your smile you would like to improve, and what your aesthetic goals are.
With the information collected, we use advanced digital analysis software to design a smile that perfectly matches your features. This software allows us to create a virtual model of what your smile will look like after treatment. You can see the final result before treatment begins, allowing you to actively participate in the design.
Depending on the patient’s needs and desires, the necessary treatments are planned to achieve the desired result. This may include dental veneers, teeth whitening, orthodontics, restorations, among others. Each step of the treatment is carefully coordinated to ensure a harmonious and natural result.
Once the plan is approved, we begin custom treatments. When the design includes veneers, porcelain or composite veneers are placed to improve the shape, color and alignment of the teeth. If orthodontics is required, invisible aligners are applied to correct the position of the teeth. The goal is to create a smile that is not only aesthetically pleasing, but also functional and healthy.
After the treatments are completed, a final review is performed to ensure that the result meets your expectations. Necessary adjustments are made to perfect the smile and ensure that you are completely satisfied with the result.
Smile Design is ideal for anyone who wants to improve their smile in a comprehensive manner. You should consider this treatment if:
Dental veneers are an effective cosmetic solution for correcting a wide variety of tooth imperfections, such as stains, wear, slight misalignments or even structural damage. At International Dental Centre, we offer two main types of veneers: composite and porcelain, each with its own specific advantages and characteristics.
Composite veneers are made of a composite resin that can be molded and sculpted directly onto the surface of the teeth. This material is very versatile and can be used to improve the shape, color and size of teeth quickly and efficiently. The procedure to place composite veneers is minimally invasive and can often be completed in a single visit. Our expert dentists apply thin layers of composite over the tooth, molding it to achieve the desired shape and then hardening it with a special light.
Composite veneers are a more affordable option and have the advantage of being reversible. In addition, should they become damaged, they can be easily repaired without the need to replace the entire veneer. However, while they are durable, they have a shorter lifespan compared to porcelain veneers and can be more susceptible to staining and wear over time.
Porcelain veneers are known for their durability and ability to mimic the natural look of teeth. These veneers are custom fabricated in a specialised dental laboratory, ensuring a perfect fit and a highly aesthetic appearance. The process of placing porcelain veneers involves two main visits. In the first, the tooth is prepared by removing a small amount of enamel to accommodate the veneer. Then, an impression of the tooth is taken and used to create the custom veneer. On the second visit, the veneer is permanently bonded to the tooth.
This type of veneer is especially recommended for correcting more severe problems such as severely discolored, worn or misaligned teeth. Porcelain veneers are stain resistant and offer superior durability, with a lifespan that can be extended for many years if properly cared for. In addition, their finish is extremely natural, reflecting light in a manner similar to natural tooth enamel.
At International Dental Centre, our mission is to help you achieve a healthy and attractive smile. We use advanced technologies and the best materials to ensure high-quality and long-lasting results. Our comprehensive and personalised approach ensures that each treatment is tailored to your specific needs and desires. We believe everyone deserves to smile with confidence, and we are here to make that dream a reality.
Contact us today to schedule a consultation and discover how our cosmetic dentistry treatments can transform you. Let our team of experts in Fuengirola help you look your best!
A bright white smile is a common desire, and at International Dental Centre we offer teeth whitening treatments to help you achieve that goal. Teeth whitening is a process that lightens the color of teeth and removes surface stains caused by food, drink or smoking. We have two main methods for whitening: in-clinic and at-home, both of which are safe and effective.
It is the gold standard whitening treatment for its predictability and convenience. We offer teeth whitening kits for at-home use. These kits include custom trays tailored to your teeth and a low concentration whitening gel. Our professionals will guide you on how to use the kit correctly to ensure you get the best possible results.
At-home whitening is a gradual process that allows you to adjust the level of whitening according to your preferences and the sensitivity of your teeth. This method is ideal for those who prefer to perform the treatment in the comfort of their own home and at their own pace. With continued use, you can achieve a visibly whiter smile within two to four weeks.
In-clinic teeth whitening is a treatment that can provide great results when used alone or in combination with home whitening if we want to achieve optimal results. Performed under the supervision of our professionals and offers fast and visible results.
We use a highly concentrated whitening gel. This process can lighten your teeth several shades in a single session of approximately one hour.
Endodontics saves your natural teeth by treating deep infections and root damage.
Our team provides emergency dental care to quickly resolve any unexpected problems.
We are here to take care of all your dental needs. You can contact us by calling or via email. Our team of professionals is ready to answer your questions and schedule an appointment at your convenience.
