Cosmetic treatments
We offer treatments designed to give you the radiant, harmonious smile you've always wanted.
Enhance yoursmile.beauty.
Orthodontics corrects dental alignment, improving both the function and appearance of your smile.
Invisible orthodontics in Fuengirola has transformed the way patients correct their dental alignment problems, offering a discreet and comfortable solution for a perfect smile. Unlike traditional braces, which are visible and often uncomfortable, invisible orthodontics uses clear aligners that fit snugly over the teeth. These aligners are virtually invisible, allowing patients to correct their teeth discreetly and without the discomfort associated with conventional methods.
At International Dental Centre, we have chosen to use SPARK technology for our invisible orthodontic treatments. SPARK is one of the most advanced options on the market, developed with cutting-edge technology to offer precise and efficient dental correction. Here are the features and advantages of SPARK invisible orthodontics that make it the ideal choice for our patients:
SPARK aligners are made of a highly transparent material, making them virtually invisible when worn. This feature is ideal for patients looking for an aesthetic option without compromising treatment effectiveness.
SPARK aligners are custom-made for each patient, based on accurate digital scans of the mouth. This ensures that each aligner fits perfectly and guides the teeth into the desired position efficiently.
SPARK uses a patented material called TruGEN™, which is stronger and more flexible than materials used in other invisible aligner systems. This allows for better fit and comfort, as well as more controlled and precise tooth movement.
Advanced digital planning is offered, allowing orthodontists to plan each tooth movement with millimetre accuracy. Patients can see a virtual simulation of the expected results, giving them a clear view of the treatment progress.
The main advantage of SPARK aligners is their discretion. The clear aligners allow patients to correct their teeth without anyone noticing, which is especially beneficial for adults and adolescents concerned about the appearance of traditional braces.
Unlike metal brackets, SPARK aligners have no metal parts or sharp edges that can cause irritation to the gums or mouth. They are removable, which facilitates oral hygiene and allows patients to enjoy their favourite foods without restrictions.
SPARK treatments usually require fewer visits to the orthodontist compared to traditional methods. This is because the aligners are delivered in sets that the patient can change at home, under the regular supervision of the orthodontist.
Thanks to advanced digital planning, SPARK treatments are highly predictable, allowing you to achieve satisfactory results in less time compared to other orthodontic systems.
SPARK aligners are easy to use and maintain. They can be removed for eating, drinking and brushing, which improves oral hygiene during treatment and reduces the risk of caries and gum problems.
At International Dental Centre, we are committed to offering the best orthodontic treatments to our patients. We have selected SPARK for its advanced technology and multiple advantages, ensuring effective, comfortable and aesthetic treatment. Our team of expert orthodontists is highly trained to design and supervise customised treatment plans to ensure optimal results.
If you are considering invisible orthodontics to correct dental alignment problems, we invite you to visit us in Fuengirola for a consultation. We will assess your specific needs and explain how SPARK technology can help you achieve the smile you’ve always wanted, discreetly and effectively. At International Dental Centre, your best smile is our priority!
Dental implants are a durable and natural option for replacing missing teeth.
Endodontics saves your natural teeth by treating deep infections and root damage.
We are here to take care of all your dental needs. You can contact us by calling or via email. Our team of professionals is ready to answer your questions and schedule an appointment at your convenience.
